Joyce
#1 Posted : Monday, October 15, 2007 5:13:37 PM(UTC)
Joyce
Originally my Magic Chef Stove CER3540AAH started beeping and the F1 error code flashed, then changed to an F3 error code, now we get just beeping with no error codes and the oven or broiler will just turn off. Any suggestions as to which part may be bad - Clock Assembly or Temp Sensor? Thanks for help!
Joyce
Pegi
#2 Posted : Monday, October 15, 2007 6:25:43 PM(UTC)
Pegi
MAGIC CHEF
Range/Stove/Oven Fault Codes
Failure
Code Condition Check/Repair
F1 1. Watchdog on board
2. Touch membrane defective To determine which component is at fault, disconnect ribbon strip. If NO fault code, replace membrane, otherwise replace board
F2 Oven too hot Check oven temperature sensor
F3 F4 Open or shorted oven temperature sensor Replace
F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
F6 Missing AC signal Replace clock assembly (also called the ERC)
F7 Function key shorted Replace touch pad
F8 Analog/Digital converter Replace clock assembly (also called the ERC)
F9 Door latch Check door lock circuit
F10 Function key stuck Replace touch pad
______________________________________________________
Daym looks like it could be any of three problems, need to find the tech sheet hidden in your range and see what it says and see if it will let you do some testing....
Joyce
#3 Posted : Monday, October 15, 2007 7:37:16 PM(UTC)
Joyce
Where do manufactures usually hide tech sheets? The only thing that was taped to the back is a wiring diagram. The clock assembly in this stove does not have a ribbon strip and the clock assembly is sold as a combination face plate and board. My husband had the clock assembly out of the stove. We thought that maybe if we reseat the board it would work properly but it didn't. We no longer get error codes, just beeping. We still have the stove plugged into electroical and the only thing running is the clock. We get single beeps every so often and when we try to use broiler or oven, they will just turn off sometimes with a beep and other times off without a beep.
Pegi
#4 Posted : Tuesday, October 16, 2007 10:50:07 AM(UTC)
Pegi
I would suspect the clock at this point, but...might be an expensive test..
Joyce
#5 Posted : Tuesday, October 16, 2007 4:16:44 PM(UTC)
Joyce
You are so helpful Pegi !! I ordered the oven sensor this morning so we should find out hopefully by weekend (if I receive it by Friday) if that is the solution to problem. If beeping continues then I'll order the clock assembly to see if that is the fix. Thanks again for your input.
Joyce
#6 Posted : Saturday, October 20, 2007 12:07:00 PM(UTC)
Joyce
Just thought I'd let everyone know that my problem with error codes was fixed after we ordered and replaced the Temperature Sensor. We received part 10/18/07 and used oven once so far as of 10/20/07 and it worked great!
Thank you Appliancepartspros and all who contribute. What a great site!!!!
