My microwave quit working, there is no lights or display at all. I have checked the power coming into the unit, OK, also checked the power in & out of the SN-UF12V card that hold the 20A fuse in & old OK and the fuse is OK. Also checked the HVT on going ionto the PCB board and thats OK, dont know what to check next.
Did you ever find out what went wrong I have the exact same problem with the same model
Originally Posted by: snolen My microwave quit working, there is no lights or display at all. I have checked the power coming into the unit, OK, also checked the power in & out of the SN-UF12V card that hold the 20A fuse in & old OK and the fuse is OK. Also checked the HVT on going ionto the PCB board and thats OK, dont know what to check next. thank you!!
