tedward77
#1 Posted : 16 years ago
tedward77
It takes our dryer 2-3 80 min cycles to dry clothes where it used to take 1. I have read suggestions you've made to other customers and this is what I've done. I have noticed during the load, that the heating coils will glow for a while, turn off, and then glow again. I took the dryer apart and cleaned out all the duct work within the dryer. I then eliminated the duct work through the house by running the dryer disconnected. The output temp of dryer without clothes is between 130 - 140 F. Once a load of wet clothes is in, the temp will remain between 95 - 100. Even with the dryer disconnected, it still takes 2-3 cylces to dry. Also, I don't know if this is relevant, but the automatic sensor dry has not been working so we just use time dry. Any suggestions?
Thank You,
Ted
#2 Posted : 16 years ago
Hi Ted,
I would recommend to replace the cycling thermostat (#230 on the break down diagram) first and check the blower wheel.
If it would not help then replace the temperature switch (#87 on the break down diagram).
Here are the break down diagrams for the GE dryer Model DCXR453EV0AA
tedward77
#3 Posted : 16 years ago
tedward77
Thanks Gene, I'll replace those parts.
Ted
#4 Posted : 16 years ago
Keep us posted.
Maytag Gas Dryer Timer not Advancing = Clothes not Drying (Dryer Repair)
by troxel 11 years ago
clothes not drying (Dryer Repair)
by wu5062@cox.net 12 years ago
Clothes not drying (Dryer Repair)
by dlw918 13 years ago
Dry has heat but clothes not drying (Dryer Repair)
by spayonk 13 years ago
dryer heats intermittently,clothes not drying properly (Dryer Repair)
by keithblake@peoplepc.com 14 years ago
by TJFox15 14 years ago
Clothes not drying compleatly (Dryer Repair)
by Marc Anderson 14 years ago
Clothes not drying complete.....GE dryer (Dryer Repair)
by FDAR 16 years ago
Top of Dryer hot but clothes not drying (Dryer Repair)
by sween 17 years ago
