diaz1023
#1 Posted : Friday, October 19, 2007 11:22:15 PM(UTC)
diaz1023
As you can see from the model and age of the fridge, it is pretty old, it think. Well it stopped cooling and freezing, my icecream is melting and that is making me sad :( , How do I go about seeing what is wrong with it? I believe you can all help me and it would be greatly appreciated
#2 Posted : Saturday, October 20, 2007 2:08:20 AM(UTC)
Remove back freezer panel and check frost pattern, if only partially frosted, you have a refrigeration system problem for a pro. to fix. If no frost, check your compressor. If not running and all fans running, you may just have a bad start relay.
I would check your three compressor pins for ohms. If ok, just replace the start relay. Click on your model # to get it.
LG Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by jesliu88 1/23/2021 8:44:04 PM(UTC)
Frigidaire refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by mrsmobley 6/10/2013 7:37:50 PM(UTC)
by carmonafam 3/31/2013 11:12:19 PM(UTC)
Frigidaire Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by cca610 11/5/2012 2:01:36 PM(UTC)
GE Profile Arctica Refrigerator Not Cooling or Freezing But Running (Refrigerator & Freezer Repair)
by mGalicia 5/29/2012 3:15:30 AM(UTC)
Maytag Plus Refrigerator not cooling or freezing (Refrigerator & Freezer Repair)
by mangman 5/12/2011 7:04:56 PM(UTC)
Maytag Refrigerator not cooling or freezing, makes buzzing on start up. (Refrigerator & Freezer Repair)
by ghartman21 12/31/2010 3:00:55 PM(UTC)
Refrigerator Not Cooling Or Freezing (Refrigerator & Freezer Repair)
by nascar_madman 5/17/2009 4:54:17 PM(UTC)
refrigerator not cooling or freezing properly. (Refrigerator & Freezer Repair)
by Bill K 4/3/2008 1:12:15 PM(UTC)
