PamG
#1 Posted : Saturday, November 15, 2008 6:58:21 AM(UTC)
PamG
I'm trying to replace the oven thermostat knob on my old range. It says Gaffers & Sattler on top, also says a div. of Magic Chef on the tag inside. I cannot read the model or serial numbers on the old tag (embossing has been smooshed), but I found some old literature that shows a model number ER51KB-2X. I ordered a knob that looked right (Maytag Knob Kit Tstat Gas 19950033), but it is too big for the existing shaft. The diameter of the existing shaft is 1/4" (measuring across the "d"), while the inside diameter of the part I got is 5/16". I don't want to just keep ordering parts that don't fit...can anyone give me a part number???
libertyappl
#2 Posted : Saturday, November 15, 2008 7:03:36 AM(UTC)
libertyappl
Did the one you purchased come with the adapters?
Nat
PamG
#3 Posted : Saturday, November 15, 2008 7:05:28 AM(UTC)
PamG
Hi Nat, yes, both of the adapters are 5/16" inside diameter...no good.
libertyappl
#4 Posted : Saturday, November 15, 2008 7:07:57 AM(UTC)
libertyappl
Can you make out any of the model number on the tag, the number posted doesn't pull up.
Nat
PamG
#5 Posted : Saturday, November 15, 2008 7:13:49 AM(UTC)
PamG
No, I can't read it for sure, it's been cleaned too many times. Try this number: ER51ks-2lx. The literature I found says that the first 5 digits are the model number (ER51K), the next number indicates color (s...presumably silver), and the last 3 number indicate features (x-black glass on oven door, etc.) hope this helps...
libertyappl
#6 Posted : Saturday, November 15, 2008 7:22:23 AM(UTC)
libertyappl
sorry that number doesn't pull up anywhere, even google. Can you take a picture of your original knob??
Nat
PamG
#7 Posted : Saturday, November 15, 2008 8:00:24 AM(UTC)
PamG
took a while to figure out how to post this....here are 2 pics, on graph paper with a 1" grid drawn on:
UserPostedImageUserPostedImage
PamG
#8 Posted : Saturday, November 15, 2008 8:13:12 AM(UTC)
PamG
When I figure out how to get the pictures posted, I'll be back..thanks!
PamG
#9 Posted : Saturday, November 15, 2008 8:19:05 AM(UTC)
PamG
Pictures of the existing thermostat knob take on graph paper with 1" grid drawn on....
PamG attached the following image(s):
v2k04
#10 Posted : Saturday, November 15, 2008 8:44:15 AM(UTC)
v2k04
Super glue it to the shaft shim it if you have to ...............if you have an ACE HARDWARE or True Value they sell a universal knob that will basically work on anything you can also find them at an Appliance Parts Retailer
Guest (5)
