Water remains in the bottom of the tub and the water is leaking out the bottom.
how can water remain in the tub if it leaks out? J/K lol
when the washer is on the water leaks out the bottom of the machine onto the floor. I don't know how it is leaking out. When I open the washer door I see water at the bottom of the tub.
Could you post your model number please?
thats not a good number it may start with a gsd or something like that the tag is on the top edge where the door closes against machine or on the door itself
got it. It was located on the inside of the door frame. GSD6560J00SS Serial HF705114B
any help???
