twieand
#1 Posted : Saturday, May 21, 2011 2:48:51 PM(UTC)
twieand
upper agitator will not spin. lower is fine. how do i find out what is wrong? how do i take apart the agitator? please advise
sidfink43
#2 Posted : Sunday, May 22, 2011 3:02:11 PM(UTC)
sidfink43
If the motor turns and it will drain then the clutch may be the problem and you need to check the brakes as well. Here is a video on the clutch,
YouTube - ‪Washing Machine Clutch Band and Lining Repair Kit Replacement (part #285790)‬‏
and check out the STicky on direct drive brakes at the top of this page.
