ericdiy
#1 Posted : Saturday, May 21, 2011 12:43:54 PM(UTC)
ericdiy
Having another error code issue. Found control board loose previously. Washer worked fine after securing board again. Drain got plugged when shag area rug was washed by mistake. Cleared the clog. Now the error code 68 is back in some cycles. If I do spin cycle only washer will drain fine. I can run permanent press cycle on cold and hot with no problems. If I try to run a longer cycle I get the error message and the washer stops working. Have to put in spin cycle only to get it to empty. I checked the control board again - it is still in place.
Eric
ericdiy
#2 Posted : Saturday, May 21, 2011 12:45:36 PM(UTC)
ericdiy
oops sorry it is 4years old now
