mbarnow
#1 Posted : Friday, November 14, 2008 1:32:43 PM(UTC)
mbarnow
Woke up the other morning and the Electric Range was dark. Checked the breaker and pulled it out to check the outlet. Everything looks fine and there is power at the outlet. Turned the breaker back on and it is still dark but there is a high pitch whistle that sounds like the timer alarm.
Thanks,
Mike
libertyappl
#2 Posted : Friday, November 14, 2008 3:09:49 PM(UTC)
libertyappl
Please post all the model number.
Nat
mbarnow
#3 Posted : Friday, November 14, 2008 5:52:31 PM(UTC)
mbarnow
Nat,
The Full Model # is 911.932880. If you need any more info let me know.
Mike
libertyappl
#4 Posted : Friday, November 14, 2008 7:33:00 PM(UTC)
libertyappl
I couldn't get the exact model number you posted to pull up. But after rereading your origial post I think that the timer alarm may have shorted out. Try to get into the control section and look for a borken or chewed wire in there. Mice can do terrible things to appliances.
Nat
mbarnow
#5 Posted : Saturday, November 15, 2008 8:35:45 AM(UTC)
mbarnow
I have updated the model number and checked for shorted wires and found none. I'm thinking the control panel has died. When it happened I didn't check to see if the burners heated up just didn't see any lights. Well the burners do heat up no lights and you still have the high pitch sound
Mike
mbarnow
#6 Posted : Sunday, November 16, 2008 7:43:19 PM(UTC)
mbarnow
After using the burners today the control panel came back to life. Any idea what is up?
Mike
libertyappl
#7 Posted : Monday, November 17, 2008 6:33:24 AM(UTC)
libertyappl
I believe you had a loose connection. Keep an eye on it and see what it does.
Nat
