jeff mitchell
#1 Posted : Friday, May 20, 2011 8:43:32 PM(UTC)
jeff mitchell
No water is coming into the tub when I select wash on hot (and only cold when I select wash on warm). Cold for cold wash, obviously. Hoses are hooked up and turned on and getting pressure to the washer. Cleaned out the screen filters but did not fix the problem. Is there a hot/cold valve that tends to stick? How to get to it? Thanks.
sidfink43
#2 Posted : Sunday, May 22, 2011 12:05:39 PM(UTC)
sidfink43
An easy test is to switch the connections on the hot and cold valves from the timer. If the hot now comes on and the cold does not, you have a problem with the valve assembly.
You need to take off the cabinet, this video will show you how.
YouTube - ‪Washing Machine Lid Switch Replacement (part #3949247)‬‏
jeff mitchell
#3 Posted : Monday, May 23, 2011 5:40:27 PM(UTC)
jeff mitchell
Thanks for the post. Problem was the hot water valve. Scalped the valve assembly off another washer that recently broke and both hot and cold are working like a champ. Problem solved.
sidfink43
#4 Posted : Tuesday, May 24, 2011 3:33:20 AM(UTC)
sidfink43
Great, glad you got it fixed and thanks for updating us.
