THenks
#1 Posted : Friday, May 20, 2011 8:48:59 AM(UTC)
THenks
My electric range just quit working. Looks like it works, but never heats up. When I unplug and plug it back in I get a code of H3 in the display. I called Maytag...useless. They said call a tech, but I'm four hours from a tech. Things can be kind of remote in Alaska. Any ideas? Thanks for the help.
#2 Posted : Friday, May 20, 2011 5:28:59 PM(UTC)
Which part of the range does not work: the surface burners or the upper or lower oven?
If any of the ovens is in question then only one of the heating elements does not work or both of them are faulty?
"H3" is not a valid error code for this kind of ranges.
Most detailed description on the problem will help us to help you.
Here are the breakdown diagrams and Replacement parts for MAYTAG MER6755AAS26 30" ELECTRIC FREESTANDING SELF CLEAN RANGE NON-CONVECT | AppliancePartsPros.com
THenks
#3 Posted : Friday, May 20, 2011 8:58:25 PM(UTC)
THenks
Gene,
Nothing heats on the oven. Neither oven heats up and none of the four stove elements heat up. It actually says H3 133. Any ideas?
#4 Posted : Saturday, May 21, 2011 1:11:15 PM(UTC)
The first thing I would do is check the circuit breakers for the range and verify 240 VAC at the wall outlet for the range. Next step is to measure voltage at the range terminal block (on the back of the range, where the power cord is connected to). The normal readings are: between the Red & White and the Black & White wires - 120 VAC; between the Red & Black wires - 240 VAC.
Post the results.
