gmeunier
#1 Posted : Friday, November 14, 2008 8:08:15 AM(UTC)
gmeunier
My washer was not spinning, so I opened up the back and found the belt laying on the floor of the washer. I purchased the new belt, but cannot get the stinkin' thing on. There does not seem to be any sort of tension release to be able to get the belt on. My wash is PILING up like CRAZY!!!! PLEASE help!!!!!:confused:
#2 Posted : Friday, November 14, 2008 12:55:13 PM(UTC)
Open the door and try to move the inner tub up & down. If it moves then the rear bearing is bad, causing the belt to fell off.
The belt is elastic and is designed to "give" enough to install it.
Here are the break down diagrams for the Frigidaire washer Model ATF7000EE0
