GIACOMO21
#1 Posted : Thursday, May 19, 2011 5:21:43 AM(UTC)
GIACOMO21
You have been a member since:: 5/19/2011(UTC)
I'm Replacing The Door Gasket. The Part You Sent Doesn't Exactly Match The Original. Top Of Gasket Has 2 Dispenser Connections. Original Has Only 1. There's No Holes In Either Of Them. Do I Choose 1 And Make A Hole & Leave The Other Blocked? At The Bottom Of The Gasket There's Another Place To Attach Something. That One Has A Hole In It. The Original Didn't Have Anything At The Bottom. Do I Plug The Hole & With What?
Thanks,
Giacomo
#2 Posted : Thursday, May 19, 2011 12:21:03 PM(UTC)
Groups ready for retrieval: Senior Expert, Administrators
The model number you posted does not come up. Verify and repost it please.
GIACOMO21
#3 Posted : Thursday, May 19, 2011 5:09:52 PM(UTC)
GIACOMO21
i misread the model # & have ordered the correct gasket. thanks for your quick reply.
#4 Posted : Thursday, May 19, 2011 5:19:15 PM(UTC)
Unfortunately I'm not able to help you if the model number does not come up.
LG front load washer part id (Washer Repair)
by Cgreen0117 3/24/2024 10:49:09 AM(UTC)
LG front load washer water leak (Washer Repair)
by Guest 7/23/2022 11:17:44 AM(UTC)
LG front load washer making grinding noise (Refrigerator & Freezer Repair)
by Guest 9/18/2021 8:57:25 AM(UTC)
LG Front Load Washer rotor only turns if given a push. (Washer Repair)
by Emailtim 6/5/2020 1:49:05 PM(UTC)
LG Front Load Washer Barely Spins (Washer Repair)
by mckennwa 3/2/2017 6:30:55 AM(UTC)
lg front load washer (Washer Repair)
by melindai 4/15/2014 4:32:46 AM(UTC)
LG front load washer repair- special LG tool to remove the door front seal spring rin (Washer Repair)
by Paul Lukitsch 2/8/2014 10:07:25 PM(UTC)
LG front load washer (Washer Repair)
by reichegw 8/14/2013 10:10:34 AM(UTC)
LG front load washer no power (Washer Repair)
by waxmanak 6/10/2013 11:35:46 AM(UTC)
Leaking LG front load washer (Washer Repair)
by klinkster 6/6/2011 8:27:07 AM(UTC)
LG front load washer (Dishwasher Repair)
by skimanforu 7/22/2010 3:48:02 PM(UTC)
by Brandon1974 6/7/2009 3:54:12 PM(UTC)
