Over the past couple of weeks I have noticed the fridge acting up. It all started when the power went out for a few hours. One day I noticed the ice looked deformed like it had melted & refroze. So I dumped it out. Next day full of ice & looked normal. 2-3 days later it does that again & the food in the freezer did not look very cold (food soft). So I raised the cold setting a little didn't make a difference. Would do this on & off for 2-3 days at a time. *Checked* -Cleaned the condensor coils underneath fridge. They were very dirty. Didn't make it any better. -Checked the evap. inside freezer & doesn't have in ice build up at all -Can move the cold settings sometimes to make compressor kick on & stay on for a little while. Still does same thing. -All the fans are working like they should (noticed the compressor was hot to the touch but might be normal)
Any help would be great! Thanks in advance
