jmambru
#1 Posted : Saturday, November 8, 2008 11:48:08 AM(UTC)
jmambru
Hello Mr. Expert;
I have a Kenmore washer it is working in good condition but now it only working with cold water. I disconnect the hot water hose to make sure there is hot water running and it is. So what part should I replace to bring it back to normal.
Thank you!!!
Jose Mambru
abadfish66
#2 Posted : Saturday, November 8, 2008 12:31:20 PM(UTC)
abadfish66
Check the screen inside the hot water side of the valve, could be clogged.
jmambru
#3 Posted : Thursday, November 13, 2008 4:07:01 PM(UTC)
jmambru
I fallowed your recommendation but it did not work out. I removed and cleaned the hot water screen and valve still not working. What can I do next.
Thank you!!!
Jose
jmambru
#4 Posted : Thursday, November 13, 2008 4:13:37 PM(UTC)
jmambru
I fallowed your recommendations by removing the valve, screen and clean it but I did not get a positive result. So what I should do next.
Thank you!!!
Jose M.
