Forum Rank:: Member
I have replace the EOC, wiring harness and control panel. The range still gives me an F1 error code and beeps constantly. The manual mentions reprogramming the oven, but gives no instructions on how to do this.
Any help would be greatly appreciated.
Maybe the F-1 is from the safety thermastat and not the control board at all The thermastat lies behind the control panel and will fail after or during a self clean the part number to the safety is frgidaire part #318005203
Forum Rank:: Member
It could be an additional problem, but the original EOC shorted out - there was a dime sized burn mark on the board. The new EOC is giving me the F1 error. The old EOC kept one of the oven elements and the convection fan on constantly.
The new EOC is the second one I've installed. The first gave me the F1 error and beeping so I returned thinking it was defective. Now the second one is giving me the error and the beeping again.
check the safety I just finished reading a service flash on it
Forum Rank:: Member
What's the safety and how do I check it? None of the manuals or parts lists have anything labeled as a 'safety'.
It's the thermal fuse if you remove the control panel its mounted behind that you csn test it with a muti meter on the ohm scale
Forum Rank:: Member
I've replace the thermal fuse and the safety (two separate parts in this model) and the F1 is still coming up. There's nothing electronic left that hasn't been replaced. Is there some way to do a reboot or reset of the programming to accept all the new parts?
