madikenn
#1 Posted : Tuesday, May 17, 2011 7:50:54 PM(UTC)
madikenn
I replaced a broken motor coupler on my washer. I put it all back together and the motor isn't working at all now. Before I replaced it the motor worked fine. I can also still spin the agitator both ways.
#2 Posted : Wednesday, May 18, 2011 1:34:48 AM(UTC)
If the motor makes no sounds at all, I would check for a partially seated plug on the side, or a bent/pushed out pin.
Motor coupler keeps breaking (Washer Repair)
by Tobyiscute 1/25/2016 8:27:49 AM(UTC)
Burning smell after replacing motor coupler (Washer Repair)
by Beerman_Supreme 6/8/2011 3:56:54 AM(UTC)
Squealing noise after changing Motor Coupler (Washer Repair)
by DanPizano 4/10/2011 11:06:41 AM(UTC)
by Moxleysr 2/4/2011 7:09:14 AM(UTC)
Washer, Kenmore 90Series Replaced motor coupler, now makes very loud noise/whistle (Washer Repair)
by Allen74 10/22/2010 12:12:20 PM(UTC)
how do you know if the motor coupler is bad? (Washer Repair)
by LHERD 12/26/2009 5:52:25 AM(UTC)
new motor coupler doesn't fit (Washer Repair)
by TDM 12/4/2009 2:41:55 PM(UTC)
Motor coupler (Washer Repair)
by DIYMom2 10/6/2009 4:10:40 PM(UTC)
Need info for replacing motor coupler (Washer Repair)
by uijongbu72 6/7/2009 11:06:17 AM(UTC)
