jgolfaholic
#1 Posted : Tuesday, May 17, 2011 7:59:47 PM(UTC)
jgolfaholic
Only problem (at least for now) is a very annoying sound that is coming from the evaporator fan in my freezer - its still cooling normally. It happened once, I unplugged the Fridge, waited about 20 minutes...good to go for a week. Now its happening daily. If I adjust the temp inside the fridge to "0" and then set back to "5" the sound stops but now its happening regularly (couple times a day). So I emptied the freezer and popped off the cover while the sound was happening - as soon as i touched the fan in the center to slow it the sound stopped. Its definitely coming from that fan. Looking online I think I should replace the evaporator fan motor... Part Details - GE Evaporator fan motor, part number: AP3798650
Hoping its as simple as it seems it will be. Any thoughts or guidence would be greatly appreciated.
jgolfaholic
#2 Posted : Wednesday, May 18, 2011 5:06:32 PM(UTC)
jgolfaholic
It must be a stumper!
