I have a Kenmore Double Oven. Some time ago the bottom oven worked intermittently flashing F1 after fully heating. Now both top and bottom ovens have stopped working. Self cleaning doesn't work - after initiating self clean it shows locked for 2 secs and then shut down. When set in any oven mode and setting the temperature - it shows 100F for about 2 sec and shut down. I removed the top oven sensor and it reads 1.05 ohm at room temperature (~75F). Do I need to replace the sensor or do I have a bigger problem?
The F1 code is a control board failure. Check your connections at the control board make sure they are snug and free of corrosion, before ordering a new control.
Nat
