I have no ice.The white plastic ice level indicator is flush or a little higher than the bottom of the unit.The door water works fine.I even think the arm has risen a little more since first inspection.I tried removing the ice maker by moving the little tab on the left but it only moved a 1/4 inch I did not want to muscle it thanks.
