shirl723
#1 Posted : 17 years ago
shirl723
Water is dripping into the tub when the washer is turned off. It seems to be coming from under the lid. Can you tell me what part to replace and how to do it?
#2 Posted : 17 years ago
Your water solenoid is bad, just click on your model # to order one.
ApplianceJunk
#3 Posted : 17 years ago
ApplianceJunk
shirl723
#4 Posted : 17 years ago
shirl723
I can't find a part named water solenoid. Is it the same as the inlet water valve?
ApplianceJunk
#5 Posted : 17 years ago
ApplianceJunk
Diagram 4, #18
Inlet water valve Part Number: AP3094541
This is the part that your hot and cold fill hoses connect to on the back of the washer.
