6 Pages«<23456>
v2k04
#31 Posted : Thursday, November 13, 2008 9:28:31 AM(UTC)
v2k04
Originally Posted by: bchristal Go to Quoted Post
Back to charging...
The neither the high or low pressure changes when the compressor is running. Are they supposed to?
if it pulls in a deep vacuum with compressor running it's restricted 20 in of vacuum would be like no freon and the pressure would rise as freon was added if it goes back in a vacuum something is plugged
abadfish66
#32 Posted : Thursday, November 13, 2008 9:39:45 AM(UTC)
abadfish66
If the bin thermister was disconected so it wouldn't run, how did you charge it with half a can, and if you don't have the hoses to do the job, just curious.
bchristal
#33 Posted : Thursday, November 13, 2008 10:09:07 AM(UTC)
bchristal
Good question, long story. I can actually add freon, just not through my guages.
I added an automotive 134a snap connector to the low side and connect the guages using this:
UserPostedImage
Then I have to remove the guages and connect a can like this:
UserPostedImage
bchristal
#34 Posted : Thursday, November 13, 2008 10:16:19 AM(UTC)
bchristal
I added the rest of my can of freon (maybe 1/4 of a can).
Low was -20 now -17
High was 94 now 240
Condensor is cool.
This probably isn't a good idea, i did it accidently. If I let the freon go from the low to the high through the hoses the condesor will get hot.
Any ideas?
abadfish66
#35 Posted : Thursday, November 13, 2008 10:32:13 AM(UTC)
abadfish66
Based on the low side pressure, looks like your heading in the right direction. It is hard to tell how much 134 your adding without measuring it. How much does the icemachine call for? It's listed on the model# tag
abadfish66
#36 Posted : Thursday, November 13, 2008 10:33:22 AM(UTC)
abadfish66
Reach underneath the evap and feel the accumulator, is it colder than room temp?
abadfish66
#37 Posted : Thursday, November 13, 2008 10:33:58 AM(UTC)
abadfish66
Also did you replace the filterdryer?
bchristal
#38 Posted : Thursday, November 13, 2008 10:35:57 AM(UTC)
bchristal
It calls for 6.5 oz by weight - added through the high side. Based on everybody's feedback about the low side vacuum it seems as if there's a clog. I was going to remove the evaporator and see if I can find a clog.
bchristal
#39 Posted : Thursday, November 13, 2008 10:38:15 AM(UTC)
bchristal
This is what the tag says:
The inside of the icemaker door has a label that says:
Design Pressure
95 PSI Low
350 PSI High
Should I add more freon?
bchristal
#40 Posted : Thursday, November 13, 2008 10:39:14 AM(UTC)
bchristal
No it's not cooling at all. It's room/tap water temperature.
Guest (6)
6 Pages«<23456>
