AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
KitchenAid Stand Alone Ice Maker - cleaning light flashes - won't make ice
They may have something at an auto parts store, they sell the cans there, they probably have the hose you need.
Originally Posted by: v2k04  go to a refrigeration supply house I used some r-12 replacement once that came in the cans and it came with a piercer and the 1/4 flare fitting it screwd on the top of can had a shut off valve The hose fitting 134a thread. R-12 looks just like 134a but it's smaller. The yellow hose on the guage has 134a. Check out my venturi pump. It has 134a and r-12 connections.
all 134 A and r-12 gauges in domestic refrigeration is 1/4 in flare we use 30 lb bottle not the little cans I was just mentioning the r-12 blend freon I bought was in a can and it had the proper fittin also automotive refrigeration fittings are different than domestic refrigeration. You can get the fitting at nappa to convert automotive to1/4 in flare I know this because I was in a jam 200 miles away from my shop and ran out of 134A I bought a 30lb jug of automotive 134A and had to find the adapter to the jug so I could hook my gages to the bottle
I'm confused. The cans you buy at the store if I'm not mistaken have automotive 134a ACME threads, and the hose you have is a standard thread that wont screw on the can...Right?, So you need the hose that fits on the can and pierces it, and also the other end needs to attach to the charge port correct? If thats the case, you need and adapter from a refrigerant supply store.
Originally Posted by: v2k04  all 134 A and r-12 gauges in domestic refrigeration is 1/4 in flare we use 30 lb bottle not the little cans I was just mentioning the r-12 blend freon I bought was in a can and it had the proper fittin also automotive refrigeration fittings are different than domestic refrigeration. You can get the fitting at nappa to convert automotive to1/4 in flare So the bottle has the valve on it? and the same threads as my yellow hose (134a threads I think). What's 1/4 flare? Thanks
Originally Posted by: abadfish66  I'm confused. The cans you buy at the store if I'm not mistaken have automotive 134a ACME threads, and the hose you have is a standard thread that wont screw on the can...Right?, So you need the hose that fits on the can and pierces it, and also the other end needs to attach to the charge port correct? If thats the case, you need and adapter from a refrigerant supply store. The hose I have WILL screw on to a can of 134a, it won't peirce it. Also, the amount threads on the can are too short, so the hose will screw on, but it won't bottom out so that the inside of the hose touches the top of threads. It won't seal. The threads on the top of the can and the threads on the charge ports are the same, except for the threads on the can are too short for the hose to seal properly. Yes, "So you need the hose that fits on the can and pierces it, and also the other end needs to attach to the charge port correct? " So they must have this at a refrigerant supply store? Thanks
Guaranteed to find what you need there. They will help you get the right stuff.
Back to charging...
The neither the high or low pressure changes when the compressor is running. Are they supposed to?
Originally Posted by: bchristal  So the bottle has the valve on it? and the same threads as my yellow hose (134a threads I think). What's 1/4 flare?
Thanks 1/4 flare is what your hoses are as you notice the schrader valve has a tapered end on it thats considered a flare fitting
