Anson
#1 Posted : 17 years ago
Anson
There is a part in my icemaker that is not exactly like the picture in diagram #3 of your parts page.
It's part #325. First, I would like to know how to remove it from the lucite housing of part #352.
The difference between my part and the drawing is that there are one-inch slotted tabs on either side of the upper rear of the unit (on mine, not on the drawing). The tabs are molded with the other white plastic piece that forms the body of part #325.
Adam / APP Team
#2 Posted : 17 years ago
Adam / APP Team
Rank: Administration
Groups: Administrators
Hello Anson,
Refering to breakdown for model GSS25KGMAWW
The breakdown ( diagram ) is only a general drawing and may not look identical to the actual part.
To remove #325 Housing crusher disp from #352 Bucket ice disp
you will need to remove any screws around the outer edge along with the #321 Retainer ring (12-pack) - e-style -.
Anson
#3 Posted : 17 years ago
Anson
Thanks for the response, Adam.
I still cannot remove the #325 box from the #352 assembly. Once again, the diagram differs from what I have. The retainer ring is visible through the lucite, but cannot be accessed without removing the #325 box. The ring is at the far end of the auger. The auger assembly is stamped with the number 197D2316A004.
