menhaden
#1 Posted : Monday, May 16, 2011 2:15:21 PM(UTC)
menhaden
My GE Oven/Microwave Combination turns itself on by itself, someties in the middle of the night. After three incidents, I decided to turn off the breaker because it might turn on when no one is home. This is a old oven, about 17 years old but seldom used, this started happening about twom months ago. I have not consulted any professional about it. What do you think and What parts do I need, this age of ovem do you think parts are still available?
#2 Posted : Monday, May 16, 2011 4:22:11 PM(UTC)
I'm assuming you are talking about the oven (the lower part of the unit). In such situation the problem most likely is a bad oven control board (#28 on the diagram). This part is still available and you can order it from Appliance Parts Pros.
- The oven control board Part number: AP2020554
menhaden
#3 Posted : Tuesday, May 17, 2011 8:53:33 PM(UTC)
menhaden
thank you very much gene, cost of part is on the high side, will think about it.....
GE XL44 Gas Range - Oven Turns On by Itself (Oven Repair (including Ranges and Cooktops))
by keywiz77 2/27/2022 9:32:21 AM(UTC)
lower oven turns on by itself (Oven Repair (including Ranges and Cooktops))
by widget925 7/23/2012 11:12:24 AM(UTC)
Viking oven turns on by itself (Oven Repair (including Ranges and Cooktops))
by jrschwein 10/16/2011 9:59:11 AM(UTC)
by valvam 2/16/2011 10:05:39 AM(UTC)
Oven turns on by itself (Oven Repair (including Ranges and Cooktops))
by hkrauss 7/27/2010 11:25:35 AM(UTC)
by cdnpatriot 12/2/2008 6:07:02 AM(UTC)
