taknpak
#1 Posted : Sunday, May 15, 2011 7:56:55 PM(UTC)
taknpak
I have a very tight area to install my dryer. The dryer's cabinet has a pre-punched vent hole in the side that is the same size as the vent in the back. It looks like a 90 degree elbow could redirect the vent to the side. Does anyone know if this would be an approved change?
magician59
#2 Posted : Monday, May 16, 2011 6:28:06 AM(UTC)
magician59
There's not much room to work inside the cabinet, unless you are able to fit a vent tube behind the motor. As long as your modification doesn't interfere with the belt pathway, or impede the rotation of the tumbler, there is nothing wrong with re-routing it.
taknpak
#3 Posted : Monday, May 16, 2011 4:57:41 PM(UTC)
taknpak
Thanks, that's what I thought but I wanted another opinion. Thad Knowles
