oldrugrat
#1 Posted : Sunday, May 15, 2011 3:59:51 PM(UTC)
oldrugrat
the dryer quit heating and about a week later the washer will not work at all. It was working great at the old place, we moved into the new place and had to put in a double pole 30 amp and run new wire, I used a 10/3 wire.
#2 Posted : Monday, May 16, 2011 5:26:48 AM(UTC)
Replacement parts for WHIRLPOOL LTE5243DQ3 LAUNDRY CENTER | AppliancePartsPros.com
See the attachment for the wiring diagram.
Since you used 10/3 I am assuming this unit is a 4 wire hook up and that the old house also used a 4 wire hook up.
Is this correct or is it something else?
The first thing I would check is the power to the unit.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
Neutral to ground should be 0 ohms.
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
File Attachment(s):
LTE243.pdf (276kb) downloaded 1 time(s).
oldrugrat
#3 Posted : Monday, May 16, 2011 4:22:10 PM(UTC)
oldrugrat
thanks so much, your advice wasnt what was wrong but it sent me on the right track. The breaker that I had installed was only hitting on one pole so I was just getting half of the amps needed. thanks again, I dont think I would have gotten it without your help.
#4 Posted : Tuesday, May 17, 2011 4:00:53 AM(UTC)
You are welcome
And thanks for getting back to us. Now when others search for a similar problem they will see what actually worked instead of just suggestions about what could be the cause.
