mstevens
#1 Posted : Wednesday, November 12, 2008 3:44:45 PM(UTC)
mstevens
I am trying to troubleshoot this range for a friend. Complaint: "Oven began acting erratic and would heat up sometimes and others it would not". I checked the range and found cooktops, fan etc. to work just fine however this time the oven/broil knob showed me no indicator light nor did it attempt to heat up. Where do I start? Thanks
#2 Posted : Wednesday, November 12, 2008 6:35:09 PM(UTC)
Check if the "auto-manual" switch is in "manual" position. Check if this switch is working properly.
Here are the break down diagrams for the Modern Maid range Model FCI122
