VWC318
#1 Posted : Wednesday, November 12, 2008 2:40:44 PM(UTC)
VWC318
The right upper burner on my Jenn Air CG206B cooktop won't ignite but the lower one will. I can light it with a match but it won't ignite by itself.
The left side works fine.
Please help me determine what I need to fix it. An ignitor? A switch?
#2 Posted : Wednesday, November 12, 2008 6:26:10 PM(UTC)
Does it click when you turn the knob "on"?
If it does not then the problem is a bad ignition switch.
If it does but the burner does not light then remove the top panel and, using a needle, clean all holes in the burner.
- The part number for the ignition switch is AP3970762
Here are the break down diagrams for the Jenn Air cooktop Model CG206B
