My Maytag Gas Oven will not heat up. Burners work fine. The oven in Bake mode stays at 100 and will not heat/ light up at all. In Clean mode it lights up normally, flames and all, and works fine but not in Bake mode. Help ?
Originally Posted by: cjklein1  My Maytag Gas Oven will not heat up. Burners work fine. The oven in Bake mode stays at 100 and will not heat/ light up at all. In Clean mode it lights up normally, flames and all, and works fine but not in Bake mode. Help ? My Maytag Gas Oven will not heat up. Burners work fine. The oven in Bake mode stays at 100 and will not heat/ light up at all. In Clean mode it lights up normally, flames and all, and works fine but not in Bake mode. Help ?
Maytag model MGR5710ADW . I replaced the oven igniter, now the broiler and cleaner work, however the oven does`nt heat up.
@cjklein1, I just installed yesterday and have the exact same issue. Did you get it resolved? If so how?
