Fridge Is Warm ,condenser Coils,back Coils All Clean. Freezer Is Working Fine. Im Thinking It Might Be Condenser Fan. If So how Do I Check & Replace It.
Here are your parts, includes a wiring diagram. Replacement parts for FRT18KD4A models | AppliancePartsPros.comThe compressor, condenser/compressor fan and the evaporator/freezer fan should all be on at the same time as they are wired in parallel. Check the wires going to the fan for 120 volts. If you have the voltage and the fan does not run it is toast. |
THIS FORUM IS DEAD!!!!!!! |
