6 Pages123>»
bchristal
#1 Posted : Wednesday, November 12, 2008 2:46:04 PM(UTC)
bchristal
Hello,
I've got a 15" KitchenAid stand alone ice maker - purchased in 2000. I just finished replacing a leaking evaporator. Now when I turn it on the clean light just flashes - nothing else happens.
It will run through the clean cycle if I select clean, just nothing if I select on. Any ideas?
v2k04
#2 Posted : Wednesday, November 12, 2008 3:19:17 PM(UTC)
v2k04
Maybe this will help If it blinks 3 times its the bin thermistpr if it blinks 5 times its the evap thermistor I think thats how it goes but you will find something here.
Repairing the Whirlpool Ice Machine
http://truetex.com/ice_machine_gi1500.pdf
bchristal
#3 Posted : Thursday, November 13, 2008 3:47:48 AM(UTC)
bchristal
I thought the machine would work without either of the thermisters? The bin thermister is not attached.
bchristal
#4 Posted : Thursday, November 13, 2008 4:26:20 AM(UTC)
bchristal
It's a single blink - one at a time.
It had the blinking light problem before I repaired the evaporator - that is sometimes I would open it to get ice - the system would be on, the light would be flashing - but no ice production.
Turning the icemaker off, then on would correct the problem. Now it just flashes no matter what and no ice production, no cycles, no compressor, just a light.
Could it be the control board?
v2k04
#5 Posted : Thursday, November 13, 2008 5:57:15 AM(UTC)
v2k04
We always disconnected the bin thermistor and they would always make ice You could have a bad board very possible if nothing is working and there isn't much diagnostics for the board. About all a guy can do is replace it and find out
bchristal
#6 Posted : Thursday, November 13, 2008 6:16:19 AM(UTC)
bchristal
Actually, if I push the clean button, it will run through the clean cycle normally. It just won't run in ice production mode. Also, I charged it through the low side. Do you think that will break anything?
abadfish66
#7 Posted : Thursday, November 13, 2008 6:32:58 AM(UTC)
abadfish66
I do know on Ge ice machines, and I believe the whirlpool is made by the same company. It wont run with the bin thermister disconnected or the cutting grid, but will default to a 25 minute harvest cycle if the evap thermister is disconnected. Another thing that can cause a clean light to blink would ba a kinked or clogged drain line or a bad auxillary pump if equipped.
bchristal
#8 Posted : Thursday, November 13, 2008 6:38:51 AM(UTC)
bchristal
Ah, my bin thermistor is not connected. That may be the problem. Resistance is supposed 10K@ 77°F (25°C). I'll check that first.
abadfish66
#9 Posted : Thursday, November 13, 2008 6:45:32 AM(UTC)
abadfish66
Keep us posted
v2k04
#10 Posted : Thursday, November 13, 2008 6:49:00 AM(UTC)
v2k04
I always charge at the low side
Guest (5)
6 Pages123>»
