hayatsinc
#1 Posted : Saturday, May 14, 2011 3:11:46 PM(UTC)
hayatsinc
I have a stackable washer/dryer, whirlpool and serial # MK5131921in my condo unit. My tenant called me up and said that it's not heating up, Does anyone know what that could be from? and How much? Thank you
PATRIOT
#2 Posted : Saturday, May 14, 2011 9:56:32 PM(UTC)
PATRIOT
If your heating element is good, it's probably item 15 or 5 on the diagram (thermostat or fuse). A cheap $2 ohm meter will tell you which one.
Dryer bulkhead replacement parts for WHIRLPOOL LTE5243DQ2 WASHER/DRYER LAUNDRY SYSTEM | AppliancePartsPros.com
#3 Posted : Sunday, May 15, 2011 2:09:24 AM(UTC)
I would check the power first.
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
If you are unfamiliar with electricity then get a pro in to check/fix the unit.
