We bought french door Electrolux used (less than a year old). Hooked up water line and after 2 hours finally got water to dispense. Stop the next day. Ice maker continued to work. Though it might be a problem with the filter so we replaced that. Now neither works. Thinking it might be water valve problem.
Please help before I pull what little hair I have left out.
Cheers
TJ
Problem resolved...Frozen water line. I guess the electronic temperature gauge is a little off.
Cheers,
TJ
Did you just increase the temp of the freezer or refrigerator?
Originally Posted by: mugsyrx  Did you just increase the temp of the freezer or refrigerator? No, I dismantled the water filter faceplate and thats when I discovered that the water line was frozen. I removed the frozen line submersed it in hot water until the ice melted and reassembled.
Was the water line in the compartment where the water filter was?
