gatorwebs
#1 Posted : Saturday, May 14, 2011 7:29:28 AM(UTC)
gatorwebs
Hello, I have recently noticed my refrig/freezer not cooling properly. I also noticed that the fan in the freezer hasn't been coming on. Is this something I can troubleshoot myself or should I find a repairman to look into this.
Thanks in advance for your advice.
Sincerely,
Patrick
#2 Posted : Saturday, May 14, 2011 8:23:35 AM(UTC)
Pull the evaporator fan motor out. If 115 volts stamped on the coil, plug it in 115 volts and see if it runs, if not, order a new one with the right model #, the one given will not work.
gatorwebs
#3 Posted : Saturday, May 14, 2011 8:38:16 AM(UTC)
gatorwebs
Thanks for the help. I'll give that a try.
Refrigerator/Freezer not cooling properly (Refrigerator & Freezer Repair)
by dollar13 7/12/2012 11:02:06 AM(UTC)
