Grace
#1 Posted : Thursday, October 18, 2007 3:36:04 PM(UTC)
Grace
my washing machine stops at the point where it should release the water. the water does not come out at all. could it be a problem with the time? please advise before i purchase a timer. thank you.
#2 Posted : Friday, October 19, 2007 1:56:50 AM(UTC)
If you can manually advance the timer and it pumps out= new timer time, get it here at appliancepartspros by clicking on model #
JOHN K DUNIGAN
#3 Posted : Friday, October 19, 2007 3:58:09 PM(UTC)
JOHN K DUNIGAN
I Have A Whirlpool Top Loading Machine, Its A Special Edition, 6 Cycle,2 Speed Motor.heavy Duty Extra Large Capacity. Machine Works Fine Until It Is Time For The Water To Spin Out Of The Tub. It Does Absolutely Nothing,as Far As The Water Coming Out. I'd Like To Know What The Problem Could Be, And What I Can Do To Correct The Problem.
Thank You
#4 Posted : Friday, October 19, 2007 4:14:46 PM(UTC)
Hi John
Does it drain?
Also, in order to provide the best accurate advise I need you to post the complete model number of your washer. You can find it under the lid.
#5 Posted : Friday, October 19, 2007 4:34:39 PM(UTC)
Hi Grace
Most likely the problem with your washer is a bad lid switch.
Does it click when you slowly open or close the lid?
If the answer is "No" then no doubt the lid switch has to be replaced.
- New lid switch and step by step instructions on how to replace the lid switch: Part number: AP3100003
- Here are the break down diagrams for the Roper washer Model RAS6233KQ0
Good luck.
Admin / APP Team
#6 Posted : Friday, October 19, 2007 4:45:28 PM(UTC)
Admin / APP Team
Rank: Administration
From John's email:
"THERE WAS NO MODEL NUMBER TAG UNDER THE LID."
Water does not come out of either shower arm (Dishwasher Repair)
by dgmoy 1/26/2008 5:03:53 PM(UTC)
