mcoffman5
#1 Posted : Thursday, November 6, 2008 5:36:09 AM(UTC)
mcoffman5
the washer tub when on the spin cycle is all over the place, I have replaced all three springs already and it is still doing the same thing, what else could be causing this?
v2k04
#2 Posted : Thursday, November 6, 2008 5:38:12 AM(UTC)
v2k04
The skate plate and suspention pads are worn out
mcoffman5
#3 Posted : Thursday, November 6, 2008 5:57:41 AM(UTC)
mcoffman5
thanks, I will replace this part
#4 Posted : Thursday, November 6, 2008 6:04:20 AM(UTC)
Look at both sides of the suspension plate, sometimes it doesn't seat right.
mcoffman5
#5 Posted : Wednesday, November 12, 2008 5:02:46 AM(UTC)
mcoffman5
Wanted to let you know that this was definitely the problem, once I removed the old skate plate the pads under it were gone. I works like a champ now. Thanks again!
v2k04
#6 Posted : Wednesday, November 12, 2008 5:14:38 AM(UTC)
v2k04
Your Welcome!! Good Job!! That's one of those 100,000 mile tuneup recommendations lol
#7 Posted : Wednesday, November 12, 2008 5:18:39 AM(UTC)
Your skate plate plastic slides may have failed from excessive shaking. To help this I routinely add a helper spring to the rear one. A six inch GE dishwasher spring WD1X1333
v2k04
#8 Posted : Wednesday, November 12, 2008 5:26:36 AM(UTC)
v2k04
The brown pads leave a residue on the skate plate and when it goes into a spin the skate plate will stick on the pads and cause it to shake suspension plate pads should be replaced every couple years.The spring in the back is just a counter weight for the motor and pump. Whirlpool started getting cheap and started producing white plastic suspension pads and those wear out in 6 months or less their junk.The brown ones lasted much longer if a person would scuff up the pads and plate every 6 months or so they would last way longer, These have just been my personnal experiences working for the giant appliance retailer as long as I did thats all I basically worked on is whirlpool
#9 Posted : Wednesday, November 12, 2008 5:43:27 AM(UTC)
Wow, thanks, I just learned something, appreciate it!
Guest (4)
