comicsurf
#1 Posted : Tuesday, November 11, 2008 5:43:07 PM(UTC)
comicsurf
I have a five year old kitchenaid superba and the leds stopped working.. Tested the door latch and thermal fuse all ok. changed out ps board with no luck , so moved on to keypad control and still not working. could it be a bad pc board? any other options?
#2 Posted : Wednesday, November 12, 2008 3:24:46 AM(UTC)
I assume the dishwasher works ok. If so, you will need to refer to the service sheet to find out where the power is missing, could be just a bad connection at a socket.
comicsurf
#3 Posted : Wednesday, November 12, 2008 4:59:38 PM(UTC)
comicsurf
no the dw is not functional, the unit jhas power to pc board but nothing is going.
comicsurf
#4 Posted : Friday, November 14, 2008 2:01:21 PM(UTC)
comicsurf
the dishwasher is still dead there is power to the unit but nothing is working. I replaced the pc board and the keypad and verified the thermal switch and the door switch is good. what else is left to do. I have switched the new pc board for the old and the leds lit up but notheing was functional. this was only temporary and soon quit completely again. any help would be appreciatedl
comicsurf
#5 Posted : Friday, November 21, 2008 3:35:20 AM(UTC)
comicsurf
finally figured it it be the ribbon cable, but thanks for the lack of help
Guest (4)
