The microwave started sparking a couple of nights ago, leaving burnt looking spots inside- still works, but there are tiny specks inside of wall that look burnt out. Timer on oven doesn't work, neither does self cleaner. We are moving soon and need to replace to sell house. What is the most economical option for us? Thanks so much!! Not very happy!!:confused:
I'm afraid you do not have much choice but replace the whole thing. The timer is no longer available for this model and arcing inside the microwave means serious problems with the cavity surface and, very possible, the magnetron.
hi. i have a vintage 1985 GE dual wave system also and my light bulb in my microwave is not working. do you know where the light bulb is and do you have a manual that tells you how to replace it?
In order to provide moist accurate advise we need the complete model number of the microwave.
hey. the complete model number is: JKP67G002BG. thanks
thank you so much for sending me the diagram.. this will help me a bunch and will come in handy. thanks again
Does anyone know if the baking element for the GE Dual Wave II is the same, regarless of model number? My oven's taking a long time to heat up and would not bake anything on the bottom so I'm assuming it's the baking element that needs replacing (Model #JKP78G0K4).
The unit is almost 20 years old and we would like to use it for another year before replacing the whole thing. Thanks for your help.
