rparinsster
#1 Posted : Monday, November 10, 2008 1:53:30 PM(UTC)
rparinsster
I need to replace the Clock/Timer Control. The front panel has two screws underneath, easy to remove, however, the enamel range top must be lifted to get at the top screws holding control panel cover. I can see two hooks holding the top down in the front, but cannot figure out the release for the actual top. It's one of those repair secrets designed to frustrate us capable homeowners from doing for ourselves, a sad comment on our society.
The schematics available on this site are not quite detailed enough to show this procedure. They are very good all that apart.
#2 Posted : Tuesday, November 11, 2008 12:57:36 PM(UTC)
You can find the complete instructions in the Service manual (pages 2-7 through 2-10). The sealed burner wrench is no longer available but you can find a similar tools in a hardware store.
- The part number for the clock is AP204798
Here are the break down diagrams for the Jenn Air range Model SCG20200B
rparinsster
#3 Posted : Tuesday, November 11, 2008 1:19:35 PM(UTC)
rparinsster
Gene, thank you. How do I cross reference the Jenn-Air model # to the Maytag for same appliance. Again. thanks, Richard
#4 Posted : Tuesday, November 11, 2008 1:55:48 PM(UTC)
Originally Posted by: rparinsster Go to Quoted Post
...How do I cross reference the Jenn-Air model # to the Maytag for same appliance...
Richard,
You can not. This is different brands.
rparinsster
#5 Posted : Tuesday, November 11, 2008 2:07:19 PM(UTC)
rparinsster
Actually I found what I needed imbedded in you firt email vs APP's reply. We are good to go, and your support has been outstanding,
Richard
