n1ktc
#1 Posted : Tuesday, November 11, 2008 9:47:31 AM(UTC)
n1ktc
I have a kenmore front loader that won't spin I have replaced the speed control, motor,and door switch. the motor will only spin if I give it a little"help" to get started.
Is there a way to test the motor outside the washer? I have followed the steps in on the tech sheet and the results tell me to replace the motor. When I replaced the motor the problem still was not fixed. I tested it again with the new motor and it fails as well. I wan't to be sure before I return the motor as defective.
v2k04
#2 Posted : Tuesday, November 11, 2008 11:51:48 AM(UTC)
v2k04
You've done about all a guy can do The tech sheet is all we have to go on and being a dc motor I don't believe there is anyway to hotwire it that I'm aware of anyway
