2 Pages12>
Meterman
#1 Posted : Tuesday, October 16, 2007 12:32:19 PM(UTC)
Meterman
This 25-yr old nat. gas cook top spark igniter module has stopped working and its direct replacement is no longer available. The module is a Harper-Wyman, Kool Lite model 6521, 120V, 4ma. that came with my Modern Maid cooktop model KGT583A, s/n004363-042 The spark module feeds three separate burner sparkers. There is plenty of room and I don't care about the type of wiring connections. Does anyone know of a substitute part that might work? Part number and where to purchase, if possible?
thanks, meterman
#2 Posted : Tuesday, October 16, 2007 8:46:49 PM(UTC)
Hi Meterman
Most likely you can use the Maytag spark module, part number AP204776
It is designed for four igniters but you can use it for three, just connect the fourth outlet to the ground.
Good luck.
Meterman
#3 Posted : Thursday, October 18, 2007 2:09:03 AM(UTC)
Meterman
Hi Meterman
Good luck.
Thank you Gene. I believe this will work and I've ordered it. In fact, my old unit actually has contacts for four igniters but the fourth post is connected to ground.
thanks again, you've probably saved me about $1000.
#4 Posted : Thursday, October 18, 2007 6:52:28 AM(UTC)
Keep me updated, please.
Meterman
#5 Posted : Thursday, October 18, 2007 6:57:39 AM(UTC)
Meterman
Will do, but it might take a week or so before I receive the part & get it installed.
Meterman
#6 Posted : Saturday, October 20, 2007 1:01:05 PM(UTC)
Meterman
Gene,
The part arrived yesterday (excellent service). I installed it this morning and it works perfectly. You just saved me over $1000. that a replacement cook top would have cost.
Thank you very much,
Jack
sotexasbob
#7 Posted : Friday, March 1, 2013 8:46:54 AM(UTC)
sotexasbob
Gene- I found this thread and you gave a part number ( AP204776 ) which I cannot find any longer. Any help as to what part replaced it? The original part was the same as Meterman's. module is a Harper-Wyman, Kool Lite model 6521, 120V, 4ma.
Any help would be greatly appreciated.
#8 Posted : Friday, March 1, 2013 12:31:12 PM(UTC)
This part number has been changed since the previous post but if you click on the old part number it will come up as Part number: AP4010034
This is pretty the same part.
sotexasbob
#9 Posted : Friday, March 1, 2013 12:33:11 PM(UTC)
sotexasbob
Thanks, Gene!!! You are a lifesaver!
#10 Posted : Friday, March 1, 2013 12:36:33 PM(UTC)
Guest (5)
2 Pages12>
