My Whirlpool Oven Wont Heat Up After I Done A Self Cleaning... After I Read A Few Froums I Think Its The Thermal Fuse...here Is My Modle Number: r5696px6b0 If Someone Knows The Part Number And Can Help Me Out I Sure Would Appercate The Help
I Have Five People To Cook For And Theres Only So Much You Can Do On A Stove Top Lol.... Thanks !!!!:d
I cannot find any info using the given model number. Tried here and the Whirlpool site. Please check it. Model Number LocatorIf this is not a USA model odds are I will not be able to find anything. I can tell you that the thermal fuse (cut-off) is usually attached to the back outside of the oven. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: denman  I cannot find any info using the given model number. Tried here and the Whirlpool site. Please check it. Model Number LocatorIf this is not a USA model odds are I will not be able to find anything. I can tell you that the thermal fuse (cut-off) is usually attached to the back outside of the oven. thank you for trying to find it for me ill take the old one off and see if i can find one somewhere
If you can get numbers off the part, then I may be able to cross reference them. |
