bounder
#1 Posted : Monday, November 10, 2008 4:12:37 PM(UTC)
bounder
washer wont spin I check the lid switch and timer found timer bad and lid switch could the pump keep it from spinning if it was clog up
#2 Posted : Tuesday, November 11, 2008 1:21:30 AM(UTC)
If it fails to pump the water out, remove the pump hoses and clean out the pump.
bounder
#3 Posted : Tuesday, November 11, 2008 4:02:09 PM(UTC)
bounder
thanks richappy for the info from bounder
