:mad: [FONT="Tahoma"][COLOR="Purple"][/COLOR][/FONT]My washing machine won't agitate. It will spin, drain, etc., but no agitate. I thought I had overfilled it so I took over half the load out and nothing. Anyone have any ideas?
If the motor runs in agitate, you have a bad agitator coupler, just yank agitator off and check. If motor is off, you probably have a stuck water level switch. Just check it with reference to the schematic.
how do you remove agitator
Push a rope under agitator and around a 2x4 on top of the washer and pry off!!
