2 Pages<12
vsuboni
#11 Posted : Monday, November 10, 2008 12:46:07 PM(UTC)
vsuboni
Hi gene,
You mean is the spark module?
Where do I find it?
Is the module under the pilot? See picture!!!!!!!!!!!!!
Thanks VasaSuboni
vsuboni attached the following image(s):
#12 Posted : Monday, November 10, 2008 1:20:02 PM(UTC)
The spark module looks like a plastic box with a few wires connected. It could be under the top panel or on the range rear panel. The wires from the ignition switch should lead you there.
vsuboni
#13 Posted : Monday, November 10, 2008 1:56:24 PM(UTC)
vsuboni
Hi Gene,
Those two blue wires from the ignition switch are leading me to the rear panel.
The panel # is 6515 4mA
[FONT='Times New Roman']They are connected to a blue plastic panel see pictures[/FONT]
[FONT='Times New Roman']COULD BE THIS ONE???[/FONT]
[FONT='Times New Roman']Thanks, Vasa Suboni[/FONT]
#14 Posted : Monday, November 10, 2008 3:11:05 PM(UTC)
Yes, you found it.
The original part is no longer available but you can use the spark module made by Maytag.
- The part number for the spark module is AP379935
vsuboni
#15 Posted : Monday, November 10, 2008 5:54:44 PM(UTC)
vsuboni
Gene, I connected the two wires on the ignition switch, would that qualify as bypass? No Klick no spark.
[FONT='Times New Roman']Thanks Vasa[/FONT]
#16 Posted : Monday, November 10, 2008 7:05:29 PM(UTC)
If you removed these wires from the switch and connected them together then you bypassed the switch.
vsuboni
#17 Posted : Wednesday, November 12, 2008 2:48:33 PM(UTC)
vsuboni
Hey Gene,
The replacement of the spark module was successful, thanks.
Gene, do I get my diploma now?????? LOL
Thanks again Vasa
#18 Posted : Wednesday, November 12, 2008 3:25:03 PM(UTC)
You are welcome. I'm glad you were able to fix it.
P.S. Your diploma is on the way.
2 Pages<12
