jim@BANCENTRE.COM
#1 Posted : Wednesday, November 5, 2008 7:38:29 PM(UTC)
jim@BANCENTRE.COM
Not Much Louder Than Normal But Sounds Different. I Looked At Bottom, There Is A White Plastic Circle That Broke Off The Cap Covering End Of Shaft And Grease On Floor.
Recommend ?
#2 Posted : Thursday, November 6, 2008 3:36:12 PM(UTC)
The model number you posted does not come up. Verify and repost it, please.
jim@BANCENTRE.COM
#3 Posted : Thursday, November 6, 2008 5:06:52 PM(UTC)
jim@BANCENTRE.COM
MODEL NUMBER SHOULD HAVE BEEN LNC6766B71
#4 Posted : Monday, November 10, 2008 12:05:53 PM(UTC)
Lift the washer from the front. Remove the belt and rotate the pump pulley (in the right rear corner). If it does not move freely then replace the pump. The new pump can look different because Maytag redesigned it.
- The part number for the pump is AP3873289
Washing machine noise in spin cycle (Washer Repair)
by jill Campbell 10/27/2010 8:25:29 AM(UTC)
