The oven does not turn on and indicator light does not turn on. The gas does not come on. The stove top turns on. The oven inside light goes on. Fan goes on. If put into clean mode the clean mode light indicator works. Just the oven appears not to be working. Any ideas?
Please post your model number for the best advise.
Nat
I have looked on the door, inside the oven and inside of the fan areas for a model number. Can't find it. It is an old stove oven combo with a jennair type down draft fan. How can I trouble shoot the problem of the oven not turning on? Its a gas stove if that helps.
Can you post a picture of the control panel? It might help us to better understand what kind of range it is.
