Invader
#1 Posted : Monday, November 10, 2008 9:05:18 AM(UTC)
Invader
I have a side by side that, as the title says, will not dispense ice or water. The water is on and the ice maker makes ice.
Talked to the local appliance part place and they say it is probably one of two boards behind the ice maker control panel. Problem is they say one of the boards is a little over $100 and the other is about $300.
Kind of would like to know for sure which board it is before dropping the $.
Any help figuring this out is appreciated.
Thanks,
Invader
libertyappl
#2 Posted : Monday, November 10, 2008 9:30:39 AM(UTC)
libertyappl
When was the last time you changed the water filter?
Nat
Invader
#3 Posted : Monday, November 10, 2008 9:32:26 AM(UTC)
Invader
Changed it Friday. Made no difference.
tdurhamjr
#4 Posted : Monday, July 28, 2014 11:21:46 AM(UTC)
tdurhamjr
I know this is an old thread but mine is doing the exact same thing. Just wondering if you ever found out what the problem was? Was it one of the two boards? how did you determine which one?
Thanks!
Tim
