I have an Americana gas range and oven. I turned off the gas service at the meter to do some work. When I turned the gas back on, I had to light the pilot lights for the range. When I tried to light the pilot for the broiler and oven, it will not light, and there is also no gas coming out of the oven burners when I turn the oven on. The range burners work fine. Is there some other reset button or vlave I need to find to get the oven working too?
Do you still have the owners manual, There is a process to get it lit and it's in there. I'll see if I can find the instructions.
Push in the oven control knob while lighting the pilot, after the pilot is lit, continue pushing the knob in for 1 minute, when released after a minute the pilot should stay lit.
